Ciemon
October 31, 2004, 3:26pm
1
Can anyone tell me how I get the wap page put in its own directory?
I host my website on the same PC as WD, so no ftp needed/used, but I want the wap page to go into it’s own …/wap directory for ease of access.
Is there a way to set this up? I can’t see it
Ciemon
In Unix you can make a symbolic link and put it just about anywhere.
Not sure about Windows since I’ve never attempted to use a Windows box as a webhost.
Will a shortcut work?
Ciemon
October 31, 2004, 4:24pm
3
I’m hosting on a windows box, and so a symlink won’t work.
I was kinda hoping that there was a way to do this with WD itself, if I was using ftp it would be a doddle.
Thanks anyway!
windy2
October 31, 2004, 6:45pm
4
i would need to add into wd the ability to set the location for the wap file on your pc…
i will do that…
Ciemon
October 31, 2004, 7:16pm
5
windy, that’d be great!
It’s so much better to be able to type wap.mywweatherpage.info than www.myweatherpage,info/index.wml
Again, I’m in the dark with hosting on windows but with apache, you can setup a virtual host that points almost anywhere.
<VirtualHost *:80>
DocumentRoot /www/vhosts/sample
ServerName www.sample.com
ErrorLog logs/sample.errors
CustomLog logs/sample.combined combined
</VirtualHost>
<VirtualHost *:80>
DocumentRoot /www/vhosts/sample/wd/wap
ServerName wap.sample.com
ErrorLog logs/wap.errors
CustomLog logs/wap.combined combined
</VirtualHost>
In the above example… www.sample.com home directory is /www/vhosts/sample but wap.sample.com is homed inside of that under /ww/vhosts/sample/wd/wap
Can you do something like that with Window’s web hosting?
Ciemon
October 31, 2004, 8:01pm
7
Yes you can, I’m using apache
The issue isn’t apache, it’s with WD putting the wap file in the directory I want it in. Currently it just goes with everything else. Because of that you must identify the page to load ie www.mywx.info/index.wml
If it’s sat in it’s own directory then a simple URL will do ie wap.mywx,info
Windy’s planned upgrade will sort it out by enabling the wap page to be placed, by WD in its own directory.
