I would like to update the firmware on my Davis VP2. The previous firmware is OK for updating via “Direct from PC” so it’s newer than the Dec 05 or whatever the date was that precluded it from being directly updated via the PC. The question is this: I am using a WeatherLink serial cable that is connected to a USB-serial port adapter cable and 3rd party driver on the computer. So selected due to the concerns with the WeatherLink USB driver issues (of which I have had none - I am using the serial cable) and the fact that the computer does not have a serial port. The virtual serial port established by the USB-serial driver shows up as COM5 (logical port - not physical). Computer is running 32 bit XP. Communicating with the VP2 through hyper-terminal on COM5 and the correct baud settings works fine. Should I have any concerns? :roll:
Many thanks Ann
