VP question
It is soon summer and I feel the need of a web project, again. I change more between software than the Bush group does its politics. Kind of like whose on first routine.
Anyway to the topic. Refresh me mind, Using WD and the tags it is capable of producting with the Vantage Pro, can the forecast generated by the VP console be independently inserted into a page. I know with the program generation, there is a scroll that trots nicely along with the other variables, but can those be independent?
Or am I all foggy again from being gone so long. :cry:
The tags are in owntemplate.txt in the wdisplay directory, it’s usually up-to-date but one slips by Brian sometimes. The VP forecast is in there;
%vpforecasttext%…Forecast text from the Davis VP
I now see it.
I appreciate the help
Now to get really motivated and do some work
debugging the errors I might make should be an all day fun filled event.
Actually, I go through this wanting to bounce between software every now and then. and the wisdom of realizing my limitations and that not everyone is interested what happens in the back yard, other that the doggie eating rabbit poops, the crazy lady in the back and who knows you might even see me not at the keyboard.
:roll:
You can also get to it in the xml output - wdfulldata.xml. The tag is
Julian
