Voice File for Weather Phone
Hello Brian,
I found a little missmatch in Weather Display. If you want to name the .wav-files for example wetter.wav in the setting, the program create this file and then this file is renamed to wetternew.wav, which you now can use. The file wetter.wav is closed and my program can’t use this file to play. Is it possible to change this procedure with the names for example that first the file wetternew.wav will created and than renamed in wetter.wav, which now can be used?
Chris
