When I open the view and correct log file screen only about 16 lines worth of data appear. The blue bar at the bottom of the box says “working” but no other lines appear. I have left the screen open for several hours thinking it just takes time to load the data, but nothing happens. I have version 1014f and have a LaCrosse 2310 stattion. How do I correct the data. Any help suggestions would be helpful. Thanks
you can just edit the log file directly
i,.e just open ii up
i.e just double click that logfile
it will then either open up notepad.exe or wordpad.exe
then delete or fix the bad data, and then save the file
this months log file is called 72004lg.txt
in the folder logfiles
also, make sure you still have the logging enabled, under setup, logfile recording
