Since downloading version W, an upgrade from version M, WD has a problem and shuts down after the 01:00 AM internet update.
is it just 1am , or other times?
maybe its to do with the mysql?
in 10.15x, the mysql is updated by a separate program (wdmysql.exe)
It is just at 1 am. I’ve got WD updating my web page every 15 minutes. After the 1 am update I get the Win XP message thqt says WD encountered a problem and is shutting down.
I find it in the morning, restart WD and everything is OK until after the 1 am update.
i can find anything significant about 1am…and no other reports of problems with that time
strange
try not having any updates around that time
before restarting WD - is there anything in the programerrorlog.txt ?
Forgot to check any of the logs :x …I reloaded version M and the problem went away…yesterday I downloaded version 10.16 and I am not having the problem…I do not haqve the mysql running.
The problem I am having with the web page not updating after the 1 AM update is still with me. Below is the program error log from last night. WD is set to update the web every 15 mnutes. The errors starting at 7:07 AM are when I opened the screen this morning, after that I get the Windows message that WD has expierenced a problem and shuts down.
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 01:15:04 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 01:30:07 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 01:45:04 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 02:00:04 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 02:15:13 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 02:30:08 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 02:45:10 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 03:00:07 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 03:15:08 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 03:30:10 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 03:45:14 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 04:00:09 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 04:15:05 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 04:30:06 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 04:45:05 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 05:00:06 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 05:15:08 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 05:30:07 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 05:45:10 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 06:00:03 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 06:01:00 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 06:15:09 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 06:30:10 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 06:45:06 08/28/04
ERROR: Access violation at address 0041B0E0 in module ‘WeatherD.exe’. Read of address 0000000F at time/date 07:00:12 08/28/04
ERROR: Access violation at address FFFFFFFF. Read of address FFFFFFFF at time/date 07:04:08 08/28/04
ERROR: Access violation at address FF64FFFF. Read of address FF64FFFF at time/date 07:04:08 08/28/04
Have you installed Windows XP Service Pack 2?
No…I haven’t talked to anyone that hasn’t had a problem doing that.
No...I haven't talked to anyone that hasn't had a problem doing that.I must be the exception then! :)
Julian
not sure whats going wrong there rick, as there is nothing sepecial in wd about 1:15
has this exception error occured again the next night?
No…version 10.16h has now been running for2 plus days without a problem. This has occurred twice, both times it was the first time wd went past 1 AM after a version upgrade. The first time it happened I went back, this time I restarted and it is now working. It was just the web page update that was effected, all the other uploads and Live Weather still were working. I’ll keep an eye on this and let you know if something else developes. Thanks.
Brian,
This error looks a lot like my problem.
I do have SP2 installed.
Greetz,
Jeroen
jeroenm, i have been wathcing your wdl, and every time i have checked, its been up to date (middle of yournight), but are you still getting problems?
The problem still exists.
Every morning i have to force quit Weather Display (task manager) and restart it again. Still haven’t got the time to do a complete reinstall.
But it looks like it freezes when i resize the screen (from system tray) in the morning to have a first look at the data from the past night.
But I still can’t pinpoint what it exactly is…
Did i say i appreciate how you help me with this problem ! Super !
I noticed the entries in the web servers access log in the morning. Someone from new zeeland Superb !
Jeroen
that would be me viewing it…i am from New Zealand :lol:
try , maybe, unticking, minimise at 3am, if its ticked, in the help, about
and make sure free memory is not ticked there also
