Vantage PRO2 + USB connection + Ubuntu
“any result other than -1 is a good sign but “U” as the com port name does not seem right”
What should the com port be for /dev/ttyUSB0? Maybe I didn’t configure the console properly.
/dev/ttyUSB0/
is what you should be setting the com port name in WD , via the manual entry ability
I went to the config.txt file and for the comport number I entered /dev/ttyUSB0 and I get this
trying to open comport 1 result → 3
*****Received count = -----------------------------> 65535
The config.txt says to use U for ttyUSB0. Is /dev/ttyUSB0 the correct way to fill in this field or is it something else? I would really like to make this work, but I am about ready to give up.
the problem now is with the version of Libc in use
change to use the libcomold.so in the deploy folder
(i.e delete the libcom.so file and rename the libcomold.so to libcom.so)
then restart consolewd
that should fix it
I renamed libcomold.so to libcom.so and I still get the same result.
Any other thoughts on how to make this work?
humm
i thought that would have been it! #-o
any ideas Yves?
Brian,
Do you have a USB Vantage Pro II to test with? If so, does it work? I am getting more and more stumped as to why this doesn’t work.
Hello all,
Made some progress with the vantage Pro Usb thanks to WeatherFront for sending me a VP pro2 USB.
If you run a kernel 2.6.23.12 or lesser you can download the driver from silab :Silicon Labs, and compile it.
just make sure you run ./configure before doing a make and make install (being root).
Reconnect the vP2 to your linux box and then check the modules cp210x is loaded (/sbin/lsmod) and /dev/ttyUSB0 is created.
I did not test with WD Linux, my objective being WdConsole.
with WdConsole, albeit not yet stable, I can see data flowing from VP to WdC,
For the ones running 2.6.24 or above be patient and hopeful, I am trying to port the cp210x to these versions. (a bit complicated)
I keep you posted.
Yves
Thanks for looking into this. I will try this with my unit this evening.
I finally was able to test this. I only ran it for about an hour, but it worked great. I had it sending CWOP data, but not wunderground or updating my website. That is a test for another time. Thanks for the great work. I am looking forward to ultimately seeing this rolled into the graphical version. Keep up the great work.
I have found a way to accommodate with the standard device driver Linux distribution offers. You might want to try the last version of WdQT Brian has updated with my modified version of the serial reader. However it seems we have some problem with serial datalogger, if you are using USB logger you should be safe.
To summarize : With a VP2 Usb data logger WdQt and consoleWd now works with kernel 2.6.24 and above with the standard cp2101.ko provided.
Yves
Yves and I have been working on some of these issues
try this update
http://www.weather-display.com/WeatherDQT.tar.gz
and there is a new consolewd update too
The updated QT version is working well. I am having problems though with getting the Wunderground and CWOP reports to work. I can’t seem to be able to set the port for CWOP and I am not sure what the Wunderground problem is yet. Thanks for the hard work. Once I am sure I can ditch Windows and Weatherlink I will be donating to the cause.
wunderground should work OK
check the case of the username/password
also check maybe its your firewall (even router) blocking it?
what port are you needed to sete to?
do you mean you cant change the port its set to ?
(I can fix that…that will be a bug with QT and the spinedit)
due to the large size of the linux and Mac versions uploads, they are going to blow my satellite internet data caps
so any donations to allow me to keep on updating is very welcome
It was a silly mistake on my part for the CWOP and Wunderground data. Running it last night I did get several crashes. I will try to document this a little better for you tonight if I get the time.
I just got this. I don’t know if it will help you or not…
TApplication.HandleException File not open
Stack trace:
$0834E176 TGRAPHFORM__WEBTABLE, line 11835 of graph.pas
$089DBEA8 TFORMTIMER1__CHECKFORUPLOADNEW2, line 40000 of timer1new.pas
$080DB0C6 TMAINFORM__DOFTPUPLOAD, line 17337 of mainunit.pas
$08150E2E TMAINFORM__UPDATEINTERNETNOWCLICK, line 54012 of mainunit.pas
$08931249 TFTPDIALOG2__TESTUPDATECLICK, line 16582 of newftpsetup.pas
$080872F4 TCONTROL__CLICK, line 2095 of ./include/control.inc
$08ACF9CF TBUTTONCONTROL__CLICK, line 57 of ./include/buttoncontrol.inc
$08AD00A5 TCUSTOMBUTTON__CLICK, line 185 of ./include/buttons.inc
$08AD0541 TBUTTON__CLICK, line 329 of ./include/buttons.inc
$08AD025A TCUSTOMBUTTON__WMDEFAULTCLICKED, line 240 of ./include/buttons.inc
$08C83EE9
$0807DF94 TWINCONTROL__WNDPROC, line 4749 of ./include/wincontrol.inc
$08B0B15D TQTWIDGET__DELIVERMESSAGE, line 3468 of qtwidgets.pas
$08B0BAFE TQTPUSHBUTTON__SLOTCLICKED, line 3802 of qtwidgets.pas
$B7BF0E55
$B7BE8DBD
$B78818F1
Stack trace:
$089B2EE4 TFORMTIMER1__TIMER1TIMER, line 28709 of timer1new.pas
$081DFB73 TFORMUNITS__TIMER4TIMER, line 32740 of units.pas
$081DE105 TFORMUNITS__UPDATETIMERNEWNOW, line 32014 of units.pas
$08AE4BB5 TCUSTOMTIMER__DOONTIMER, line 182 of customtimer.pas
$08AE4B1F TCUSTOMTIMER__TIMER, line 157 of customtimer.pas
$08B1D873 TQTTIMER__EVENTFILTER, line 3303 of qtobjects.pas
$B7BF027D
$B786CC89
$B6F79129
$B6F7DDC9
$B786C969
$B789A1A0
$B78979B0
$B6C93CC6
$B6C97083
** GLib:ERROR:(/build/buildd/glib2.0-2.16.6/glib/gmain.c:2015):g_main_dispatch: assertion failed: (current->source == &current_source_link)
./GoWeather.sh: line 27: 6322 Aborted $DIR_PATH/WeatherD
