This is an old problem:
The driver that kernel loads automatically when you connect the station doesn’t work, you need to download the driver of scilab and try to compile:
But there are more problems, when you compile the driver and you try to load with modprobe I have this error:
FATAL: Module ./cp210x.ko not found.
but the module it’s present.
I wrote to the costumer services of scilab, but they don’t provide any solution. I’ve tried with other distributions like Mandriva, and recompiling the kernel, but the problem persists
Try with this solutions, perhaps you will have more luck.
I think it is impossible for now to use VP2 + USB + linux. :oops:
