HI
I think I know now what might be wrong
you have the space delimeter in the output as a space instead of a comma (which WD is expecting ( I can change it to also check for a space)
so try changing the output from the station to have a comma as the space de limiter
Hi there Brian!
I don’t think I can change the output from a space to a coma, unfortunately I don’t have access to the datalogger, the manufacturer locked it, what else can we do???
Thanks for the replys
Emilio
ah
OK
I will upload a new version now that will check or a space instead of a comma
stand by, I will let you know when its ready
All right!!!
I’ll give it a try and let you know what happened!!
Thank you so much!!
I Install the update but still is not working :(… the raw data is ok, but the wind readings are still way off in WD, are there are some additional settings that I need to do??
thanks in advance
Emilio
what now shows in the WS2010/WS2500 data window?
we will crack this, we will get there
Hi there,
Sorry for the late reply, this is the raw data in the WS2012/WS2500 window…
Thank you for your time!!
WIND 7.3 265
WIND 7.3 265
WIND 7.3 265
WIND 7.3 265
WIND 7.3 257
WIND 7.3 257
WIND 7.3 257
WIND 7.3 257
WIND 7.3 257
WIND 5.6 252
WIND 5.6 252
WIND 5.6 252
WIND 5.6 252
WIND 5.6 252
WIND 6.4 228
WIND 6.4 228
WIND 6.4 228
WIND 6.4 228
WIND 6.4 228
PTU 24.0 24.0 23.9 62 72 62 16.4 16.8 15.8 1008.8 1009.0 1008.8 0.00 0.0 0.0 0.00 0.0 0.0 13.77
WIND 4.3 298
WIND 4.3 298
WIND 4.3 298
WIND 4.3 298
WIND 4.3 298
WIND 2.7 278
WIND 2.7 278
WIND 2.7 278
it looks like you have it set to the WXt510 weather station type in WD?
set it back to the Maws station type
and see how that works (now that I have allowed for a space as the de limiter)
Hi there
I set the station to MAWS201M and these are the readings, now all sensors are off in WD, any thoughts??
Loaded all time records
loading the data file month82012.inf
#Connecting com port 1
Com port connected OK → 1
wind found
13,156,288
raw data to be used for the windspeed 288
raw data to be used for the direction 156
wind found
13,156,288
wind found
13,156,288
wind found
13,156,288
wind found
13,156,288
wind found
13,146,285
raw data to be used for the windspeed 285
raw data to be used for the direction 146
wind found
13,146,285
wind found
13,146,285
wind found
13,146,285
wind found
13,146,285
wind found
13,141,286
raw data to be used for the windspeed 286
raw data to be used for the direction 141
wind found
humm
what I will do is re write the Maws code
so that it gets the data like the WXt510 code
and then parse that
will do that now…
will have a new update out soon for you to try
Still no readings in WD… these are raw data readings
WIND
converted data
converted data
converted data 6.2
converted data
converted data 260
WIND 6.2 260
converted data
WIND
converted data
converted data
converted data 6.2
converted data
converted data 260
WIND 6.2 260
converted data
WIND
converted data
converted data
converted data 6.2
converted data
converted data 260
PTU 26.3 26.3 26.3 53 55 50 16.0 16.3 15.8 1006.7 1007.1 1006.6 0.00 0.0 0.0 0.00 0.0 0.0 13.74
converted data
PTU 26.3
converted data
converted data 26.3
converted data
converted data 26.3
converted data
converted data 53
converted data
converted data 55
converted data
converted data 50
converted data
converted data 16.0
converted data
converted data 16.3
converted data
converted data 15.8
converted data
converted data 1006.7 1007.1 1006.6 0.00
converted data
converted data
converted data
converted data
converted data 0.0
converted data
converted data
converted data 0.0 0.00
converted data
converted data
converted data
converted data
converted data 0.0
converted data
converted data
converted data 0.0
converted data 13.74
WIND 12.0 269
converted data
WIND
converted data
converted data 12.0
converted data
converted data 269
WIND 12.0 269
converted data
WIND
converted data
converted data 12.0
converted data
converted data 269
WIND 12.0 269
converted data
WIND
converted data
converted data 12.0
converted data
converted data 269
WIND 12.0 269
converted data
WIND
converted data
converted data 12.0
converted data
converted data 269
WIND 12.0 269
converted data
WIND
converted data
converted data 12.0
converted data
converted data 269
WIND 11.9 261
converted data
WIND
converted data
converted data 11.9
converted data
oh, I forgot to put a index number after the word converted
so can see what value is where
doing that now
standby
we are making progress
try
http://www.weather-display.com/downloadfiles/WeatherDtest.zip
again
and post here what shows in the ws2010/ws2500 data window
which should show the data positions
so I can get it parsed correct
Hi there,
I still don’t have readings in WD, but the raw data is perfect! these are the readings in the ws2010/ws2500 data window
Thanks for trying so hard!!!
WIND 5.6 288
WIND 5.6 288
WIND 5.6 288
WIND 5.3 268
WIND 5.3 268
WIND 5.3 268
WIND 5.3 268
WIND 5.3 268
WIND 4.3 278
WIND 4.3 278
WIND 4.3 278
WIND 4.3 278
WIND 4.3 278
WIND 4.1 262
WIND 4.1 262
WIND 4.1 262
WIND 4.1 262
WIND 4.1 262
WIND 4.3 266
WIND 4.3 266
WIND 4.3 266
WIND 4.3 266
WIND 4.3 266
WIND 3.9 255
WIND 3.9 255
WIND 3.9 255
WIND 3.9 255
WIND 3.9 255
PTU 26.1 26.1 26.1 58 67 58 17.2 17.7 17.1 1007.6 1007.6 1007.4 0.00 0.0 0.0 0.00 0.0 0.0 13.74
WIND 4.0 260
WIND 4.0 260
WIND 4.0 260
WIND 4.0 260
WIND 4.0 260
WIND 3.5 260
WIND 3.5 260
WIND 3.5 260
WIND 3.5 260
WIND 3.5 260
WIND 2.6 274
WIND 2.6 274
WIND 2.6 274
WIND 2.6 274
WIND 2.6 274
WIND 4.1 266
WIND 4.1 266
WIND 4.1 266
WIND 4.1 266
WIND 4.1 266
WIND 4.5 287
WIND 4.5 287
WIND 4.5 287
WIND 4.5 287
WIND 4.5 287
WIND 5.7 281
WIND 5.7 281
WIND 5.7 281
WIND 5.7 281
WIND 5.7 281
WIND 5.4 282
it looks like you have switched to using the WXT510 instead of Maws in the weather station type setup?
it needs to be set to Maws station type
and then post what shows in the WS2010/WS2500 data window
Uppsss…sorry for posting the wrong data!!
here is the raw data using the MAWS station type, and I don’t see readings in WD!!
thanks!
converted data 1->
WIND
converted data 2->
converted data 3->
converted data 4->9.5
converted data 5->
converted data 6->248
raw →
WIND 9.5 248
converted data 1->
WIND
converted data 2->
converted data 3->
converted data 5->
raw →
PTU 30.3 30.3 30.3 33 35 30 12.3 13.5 11.3 1005.5 1005.7 1005.3 0.00 0.0 0.0 0.00 0.0 0.0 13.68
converted data 1->
PTU 30.3
converted data 2->
converted data 3-> 30.3
converted data 4->
converted data 5-> 30.3
converted data 6->
converted data 7-> 33
converted data 8->
converted data 9-> 35
converted data 10->
converted data 11-> 30
converted data 12->
converted data 13-> 12.3
converted data 14->
converted data 15-> 13.5
converted data 16->
converted data 17-> 11.3
converted data 18->
converted data 19-> 1005.5 1005.7 1005.3 0.00
converted data 20->
converted data 21->
converted data 22->
converted data 23->
converted data 24->0.0
converted data 25->
converted data 26->
converted data 27->0.0 0.00
converted data 28->
converted data 29->
converted data 30->
converted data 31->
converted data 32->0.0
converted data 33->
converted data 34->
converted data 35->0.0
converted data 36->13.68
raw →
WIND 13.7 271
converted data 1->
WIND
converted data 2->
converted data 3->13.7
converted data 4->
converted data 5->271
OK
believe it or not
I just need to now deal with the control characters (CR and LF) that are in the data
will do that now
and see if I can tidy up the data positioning
