v3.03 Released
The only issue is with snowfall - if you want to be able to switch units then you need 10.20I and I think there may still be a bug with that - see Snow fall in inches
Otherwise you can use the same version of WD as for 3.02. Next version of WDL will allow you to playback previous lightning log files and you will need latest version of WD for that - but I’ve yet to code it!
Julian
