The only issue is with snowfall - if you want to be able to switch units then you need 10.20I and I think there may still be a bug with that - see Snow fall in inches
Otherwise you can use the same version of WD as for 3.02. Next version of WDL will allow you to playback previous lightning log files and you will need latest version of WD for that - but I’ve yet to code it!
is it just me or can someone else check this please?
I have been looking at Aardvark’s WDL 3.03 at http://home.mchsi.com/~dsmweather/ and checking out the windspeed or wind direction live graphs, the update is too quick - like every 2 seconds whereas data updates are less frequent, so the graph looks flatlined even when windy most of the time.
and the time is going backwards and forwards?!?!
Shouldn’t the update be a bit slower?
Is it WDL or something the aardvark has put in the config?
i am around for the next 2 hours Julian (then off on a school outing (and I was at a school leavers dinner last night, giving out certificates (busy busy!)
