Ok, a new 9.96c is uploading now that fixes a bug where the xml file was not being uploaded correctly if you were using the customise internet and file creation (it updates/uploads at the times you set for the wxlocal.htm (even if that file does not exist)
now, i have the xml feature in use at the main WD web site, http://www.weather-display.com
to do that, all i had to do was add this code:
to somwhere in your html code for you web page (i,.e it may not be your weather page, it could be your home page, business page, etc, that is not udpated)
and then to show the data, example:
