Using Weather-Display in Client Mode
This FAQ describes how to set up Weather-Display to run as a stationless client using data from another Weather-Display system. The clientraw.txt datafile can either be uploaded to a webserver or be on a drive accessible via a network by the client machine. The set up of the source system to upload the clientraw.txt file to a webserver is described in another FAQ here http://discourse.weather-watch.com/t/10872
Please post any questions about this FAQ in this thread http://discourse.weather-watch.com in the Questions forum.
Install Weather-Display
Select the Control Panel
Select Weather Station type and station settings
Select the Stationless/WLK tab and check the Stationless box
Close the Station selection window
Return to the Control Panel and select FTP/Internet…Client Server setup
Select the TCP/IP Client Server tab
Web Option: Set up the client to read data from a webserver (jump to option 2 below to read data on a mapped drive)
Check the The data is from over the internet box and enter the URL for the clientraw.txt file in the box
Mapped/Network Drive Option: Set up the client to read data from a mapped/network drive (jump this step if the internet connection has been set up in the previous step)
Push the Set location for clientraw.txt button, this will bring up the Select Directory window. Select the drive and directory and push the OK button
Check the Use clientraw.txt… box
The following steps apply to both web and network configurations
Switch on the Client Enabled switch
Set the main switch on and push the OK button
Save and Exit and restart Weather-Display and it should work
