Has anyone run a WM-918 via a USB to serial converter?
If so what Com port in WD did you have to select (I don’t see USB listed as a selectable option and can’t recall seeing USB ports being given a Com port number).
Brian - any thoughts on this please?
(I want to move the weather station to a machine that only has USB ports free…)
the software that comes with the usb adaptor gets winodws to allocate the com port number, and to find that number, simply go to control panel, system, hardware, device manager, and select ports, then it will be listed there (usb serial adaptor and the com port number)
the latest USB serial adaptors are now very good, with good drivers
the earlier ones had problems
