Hi. How can I update the clientraw.txt and clientrawextra.txt to a connected web-server without using FTP?
Ottar
Ottar
When you say local do you mean it’s on the same local network as the WD PC? If so there are several options. Or is it a remote webserver but you just don’t have FTP access to it?
Julian
It is a LAN.
Well you can either just change the location of the webfiles folder in WD - use a share on the destination webserver, or write a little vbs file to copy the clientraw file across at a regular interval, or I use a program called Ghostfiles which is a service that sits in the background and copies files automatically when it is changed.
Julian
OK. I will try one of these. Thanks.
Ottar
you actualy need to set the clientraw location in wd:
go to setup, control panel, ftp/internet setup
then client/server setup
then click on set location for clientraw.txt
and select the directory needed
