Hi all,
Yesterday I thought I would give my WD an update from b266 to b281, but that didn’t work out the way I wanted it to go. I notice a few issues (see below) resulting in downgrading WD back to b266 this morning (and so far working with out any problem). Things i noticed after updating to b281:
by the way: I used the install file and not the update file
Issues:
- [li]Rainfall multiplied by 20 times
Yesterday we had some extreme weather in the Netherlands resulting in roughly 13mm of rain in a few hours. After the update to b281 the rainfall had multiplied with 20 to 285mm. I had to manually adjust the rainfall yesterday. See image below
[/li]
[li]Control Panel Icons do not respond
This is already being discussed in this topic: http://discourse.weather-watch.com/t/59922
[/li]
[li]No update of FTP files
Weather-Display FTP and Weather-Display weather data were only updated for the first 2 times (every 5 mins) after that no update of these files anymore
[/li]
[li]Errors in programerrorlog.txt
As of the installation of b281 the programerrorlog is being flooded with the following errors:
ERROR: Access violation at address 00409E4A in module 'WeatherDisplay.exe'. Read of address 4F4C1032 System.SysUtils System.SysUtils at time/date 13:14 25/07/15
Above error or program log occured at :13:14 25/07/15
error with doftpupload Access violation at address 004D8574 in module 'WeatherDisplay.exe'. Read of address 4F4C1032
Above error or program log occured at :13:15 25/07/15
ERROR: Access violation at address 0053385A in module 'WeatherDisplay.exe'. Read of address 00000092 System.SysUtils System.SysUtils at time/date 17:37 25/07/15
Above error or program log occured at :17:37 25/07/15
error with rain icon Access violation at address 0052E121 in module 'WeatherDisplay.exe'. Read of address 0000007A
error with do timer 1 units Access violation at address 0052E121 in module 'WeatherDisplay.exe'. Read of address 0000007A
ERROR: Access violation at address 77699E03 in module 'ntdll.dll'. Write of address 00000014 System.SysUtils System.SysUtils at time/date 17:37 25/07/15
- [li]WD freezes
After upgrading WD seems to hang/freezes operation. Nothing can be accessed and it seems that WD has stopped working totally. Probably being discussed in this topic: http://discourse.weather-watch.com/t/60295[/li]
