Units on the webgraph
I am using 9.87d, and on the web-graph the wind-units are now in bft (great) but the units (2…4…6…8…10…12) are not shown.
The graph is also ‘higher’ then the one on the pc, almost double in value.
Cheers
Michiel
http://home.pi.be/~zeilgav/weer/wx.html[/url]
ok, i did delve into the code and copied over from the main screen code what was needed…
but i must have missed some important info
so i will do some testing/fixing soon
thanks
i have, hopefully, made some improvements here, with the latest version
please try
Thanks for the adjustments, the units are now displayed on the web-graph !
I use WD with Metar on my pc, and if i look at de wind dial on the left (the round one), it now shows 2 BFT, the graph on the pc shows 1 BFT and the webgraph shows 3 BFT.
The WD running with the weatherstation is more difficult to check, but there is clearly a difference between the graph on the pc and the webgraph.
But the difference is smaller then it used to be.
I haven’t had the possibility to check it in stronger winds, it is quite calm here lately.
cheers
Michiel
