Units on the Autoscale graph
I have set the units to Beaufort but in the autoscale graphs, it shows in knots
I can change all the other units, for example if I set the temperature to F, it works perfectly
This is also so for the web-version of the main graph.
Cheers,
Michiel
WD 9.85B - P4 1.6 Ghz 256 MB - Lacrosse 2310
i have not enabled the use of BFT on the autoscale grpahs
maybe i get time soon…(there is alot of code to add)
but otherwise, which main graph are you refering to?
thanks
For the autoscale graph : we will wait, no problem,
For the main graph : this is the one, I don’t know what its called
(alt+p)[/img]
thanks
Michiel
www.zeilclubgavermeer.be
ah, ok, i can convert that one too…
but why do yoiu want bft on the graph?
you will loose lots of resolution
hi Brian,
why do you lose resolution in beaufort ?
I know it is not the most up to date kind of units, but here (belgium) everybody speaks in beaufort, well, most sailors do. ( I here you have some very good ones in New Zealand as well !! )
Cheers,
Michiel
i thought that is obvious
bft is a scale from 1 to 12
which is 0 to 64 knots
that is a large resolution loss
i.e the graphing of the windspeed line will be more chunky
yes, but when I look at the main graph, not te one on the internet,
this one is in beaufort,
this doesnt look more chunky then when I put it in Knots of KM/H.
It seems to use decimal beauforts or something
cheers
Michiel
actualy you are correct
