Ubuntu 11.10 wubi
Hi!
i could also not start the wdisplay on Ubuntu 11.10
./GoWeather.sh Line 27: ./WeatherD: not found
did it run on another version?
regards
Peter
that error usually happens if you have 64 bit linux
(WD linux is 32 bit)
or if you do not have 32 library files installed for GTK2 widget or similar
hello!
i installed it but next problem unter 11.10
./WeatherD: error while loading shared libraries: libX11.so.6: cannot open shared object file: No such file or directory
what is the next step?
thank you
Peter
i searched all here http://pkgs.org/
