Hello,
I just got my VP2 and so far all is good, I have the 30 day trial of WD and am running that and uploading to a website now, being new I would still like to run Weatherlink, can this be done with different pull times, I’m not sure even how much data the VP2 will store in hours that is. I could just manually retrieve that with the Weatherlink program but I’m now updating CWOP with it.
ToppDogg
If I understand correctly…
You can upload CWOP data with Weather Display. (there isn’t much that Weather Display doen’t do)
In Weather Display go to Control Panel>CWOP to set that up.
If you want to run both Weather Display and Weatherlink, you can do so by using this program:
Virtual Vp http://www.softwx.com/weather/virtualvp.html
Softwx support forum is here: http://www.weather-watch.com/smf/index.php?board=48.0
