Trying to get back in the saddle again
8O
With the Vantage Pro - solar/UV unit. I also have soil moisture - 2 probes, 2- soil temperature probes. on extra that I use for a surface temperature. All these in that soil moisture transmitter add on.
Now… Is there any way that I can get these to graph. I get the screen that pops up and shows these and they concur with the console.
The extra temperatue / humidity sensors are either not for my set up or are for some other station. Anyway, I have tweaked these and got no results.
Is my option the VP UV/Solar Graph?
make sure you have those sensors ticked under setup, weather station type, davis vp optional accerersoies
and set them to yes there
then they should plot on the davis VP uv/solar real time graph
