Trouble with graphic.......
Hi…
At first sorry for my english…i’ m italian.
I have a trouble with grafhic,if you see my website you can understand.(pressure last 30 days)
http://www.webalice.it/dado79/macro/index.html
If i try to send on my web server only clientrawdaily or clientrawextra its all ok,
but with both client there is this problem.
Any can help me?
Make sure you’re using the latest version of WD which has the latest FTP upload software.
Julian
i use 10.19j its ok?
Should be OK. Are there any problems in your FTP log?
Julian
make sure you are also using a recent clientrawrealtimeftp.exe program
i.e did you do a full install, to get that file updated?
i can use only client raw ftp #2 ,
the #1 make error 146 please specify a remote file for updating,but i did it.
i use ver 3.0 and 3.3. #-o #-o #-o
wich client raw ftp real time uploading clientrawdaily and clientrawextra ?
thank!
i will get the 2nd one updated for the next full version release
The same problem…
I try to restart all,but i have the same problem with graphics last 30 days.
What should i do?
which graph is that of ?
(i dont understand the language used you see)
which vesion of WD are you using as well?
the clientrawdaily.txt must be there and uploaded as that graph does show data
It must be a problem with the clientrawdaily.txt file not getting to your website or at least to the correct place. It may be that your webserver is returning a 404 file not found page which WDL is attempting to parse and giving you the incorrect data.
Julian
