Could you for both %highsolar% and %highuv% tags add a tag which indicates when the occasion happened?
Thanks a lot!
Thanks a lot!
added it now to a new 10.13x beta, uploading now:
%highsolartime%…Time that the daily high solar occured
%lowsolartime%…Time that the daily low solar occured
%highuvtime%…Time that the daily high UV occured
%lowuvtime%…Time that the daily low UV occured
(note its not restrospective, will work as those values are reset/exceeded)
Thanks for adding Brian. I tried the latest version but WD does not seem to recognise the tags. The tags are not replaced with the values… Both values are exceeded too but no change…
try a download again…you migth have got an older 10.13x
Ok, works fine now! Great Thanks again!
