I wonder if it’s possible to synchronize the Vantage Pro console clock with the PC clock. I have my PC clock synchronized every hour with a time server on the net. It would be a nice feature because the Vantage Pro console clock isn’t very accurate. It’s 2 minutes behind in only 6 days…
The ooption is still there in 10.13x, under setup/control panel/weather station data logger, I just tested it manually, and all seems ok, although I tested it automatically last week, and it did still have issues, (Brian is aware of them) in automatic mode, it reset’s the clock at 6.05am daily.
cheers
hio
no, i do not know how to set the console time of the wmr968…from the pc time
i am not sure if its possible even
the wmr968 has a time sync, via radio, though…do you get that sync in europe?
so do do you mean the other way around?
(station set the pc time?)
I don’t know if you’re a german citizen, but I want to answer your remarks:
The frequency of 433MHz is aproved for use of such devices in Germany.
The 968 is using the same transmitters as the 628(N) which is aproved in Germany. So I don’t see a problem using the 968!
The difference between 928N and 968 is the decoder for the time sync signal (in Germany it’s called DCF77 and there’s an other standard in the United States).
CE is no aproval sign of any german official buro for the usage of radio frequencies. This is only given by the "Deutsche Regulierungsbeh
