Hello
The Bray Barometer v4 board which is available from Hobby Boards
Is it compatible with weather display does anyone have one working please with WD
Thank you John
Hello
Thank you John
We had no problem with getting the earlier verison working .
Should be no problem getting it working ( aye Brian )
I don’t think there will be too many changes from the last versions ( probably work fine )
If there’s a problem the best way to sort it out is to send a unit to Brian . He’ll get it sorted out quickly.
Can you post a URL link to the V4 version ( I’d like to see if there’s any changes from the earlier version I’ve got )
Hi attached url
http://www.hobby-boards.com/1wireboards/bb4-r3_bray_barometer.html
Yeh I was aware the ver1 worked ok
so I did not think to much and thought ver4 would be ok
More than likely is, maybe something is not configured correctly.
If Brian you are not opposed to taking a look at it absolutely no rush
Ill send it to you for an opinion. Excuse me if I am be presumptuous
Kind regards John
yes, you can send it to me and will try it here
Brian Hamilton
2 Marshall road
RD4
Waiuku
hi john
i have the barometer here now
I have plugged it in
WD found it ok (as a humidity rom id (thats OK)
and so i set that rom id for the barometer ID, ticked I had a barometer
went save and exit, and then wd allocated it…
but to get the baro info screen up, i had to close then re open the dallas 1 wire setup page
( i need to fix that)
i get a OK temperature reading too , so that good
but i need to know is the hi/lo baro and hi/lo voltage readings needed…
that should have been supplied…
do you have that info?
also, can i add your WDL to the links page?
