If someone would be so kind to look at my site. The frecast text is being cut off at the end. It seems to be inside the parameters??
Checked your site. I am unable to tell what is supposed to be where…I had text and icons going off both sides of my screen. #-o
The size of the Flash display is 550x400 pixels and you don’t want to go outside that. Your temperature and current conditions text are both partly outside this area. The best way to set up and test your config file so this doesn’t happen is to use the projector file - wdlv3_06.exe - which is in the download package. Using this file you can quickly and easily see the results of changes and check the positioning.
Have a look at the Configuring WDL pdf guide which explains how to do this.
Julian
