testtags.php upload failure, what's wrong ?
I am not sure if that would make a difference. I know that Brian made some changes to that program to show the file be uploaded but I am not sure when.
Chuck
Where to get the latest ftp client ?
Must go work now :frowning: I will follow the thread when free.
Mario
You could probably get it from Brian. Like I said I am not sure if that is the problem. Brian would know more about that.
Chuck
The current one should be in the latest full download.
What is the name of the ftp client file ?
No the full package of WD should have current version of that file in it.
http://www.weather-display.com/files.php
First download.
After you download and install that, download and install the ZIP file version (has a newer date) as that has the most recent WD program itself.
Then run WD and you should have the most up to date.
I’m a little reluctant to install the latest release because I already performed this task yesterday but after the update there was a problem in getting the data from the VP datalogger using Virtual VP.
I made several attempt, all failed.
I then rollback to a previous release and data from datalogger are now correctly handled.
I finally solved the problem :smiley:
  • I made a backup of wdisplay folder and subfolders
  • Then uninstalled WD and manually deleted the wdisplay folder
  • deleted a wdisplay tree in registry
  • installed the latest 10.37g build14 release
  • configured as needed (station type, latitude)
  • restored the previously saved datafiles and logfiles folders
  • I’m now just uploading the various clientraw files + testtags.php
Data upload run fine at the moment, I only need to customize some WD options and fix some minor glitch with old weather data import.
A BIG thanks to all of you for helping me!
Greetings,
Mario
I am glad you got it working MD5.
Chuck
