Testing on local can't find files
Hi all,
I’m testing Weather Display Live on my local machine.
The help says that I must put the following files in the folder to test locally.
clientraw.txt
clientrawextra.txt
clientrawdaily.txt
Can someone lead me to them? I’ve done a search and they are not on the HD.
weather display should create them in the web files folder
but only if you have set WD to do that
i.e under setup, control panel, webfiles/web page setup, real time ftp setup, then tick to do the real time client raw
(but tick, no ftp needed if you do not want that, at this stage)
Thanks, I’ll give that a try this evening…
Scott
