The temperature display in WD has been displayed at 34.2 degrees F for several days. The console reading is correct. The humidity is also incorrectly displayed at 30%. When I restart WD, it will upload and correct momentarily, then revert to the incorrect display. Any ideas??
:o With Brian’s help, this is now corrected. The temp/humidity sensor had changed from “0” to"1". After changing back to “0”, everything is working correctly.
