Hi - I have an OS WMR180 weather station connected to the trial version of weather-display software - all the data is showing up on screen except the outside temperature which is stuck at 13C. I have reset everything I can think of but the display is not picking up the temperature - it shows up correctly on the OS weather station unit under channel 3 but just shows 13C on the laptop display. Is this expected behaviour for the trial version or is there something else I need to setup to get temperature(and humidity) data to show up? thanks!
I’m not familiar with a WMR180 but Under Control Panel > Station Type & Settings > Oregon Scientific there is a setting for “Sensor # for outside Temp/Hum . . . for WMR200/300”. You could try a few options here?
Absolutely fabulous! That worked - just changed the #3 AND IT FOUND IT! Many thanks.
Closed - Over 6 months since last post
