Tempdial
Hi Brian I dont know if this is a bug, probably not though Ill post it in here anyway. The “temp dial” under the webfiles folder.
Can you see if you can make the dial fit into the picture ? SOme of the numbers are cut off which is the 0 and the 130. Thanks.
Brain did you receive my email a few days ago ? I didnt know if you were busy doing other things.
is that the individual dial image?
Yes.
try a new 9.79d
The numbers are still cut off.
ok, i have fixed this now (and tested, promise)
i will let you know when that vers is ready
vers 9.80b, ready now, will be OK
Thanks Brain ! :slight_smile:
