I can find the tags for the max and min daily soil temps but can’t seem to find tags for the time of said occurrences. Do they exist?
Do you have the Davis soil temp sensors or another.
Chuck
Hi Chuck, yes they are Davis soil temp sensors.
Would these work for you hydrowx.
VP soil temp/moisture/extra temperature/humidity ==================================================%VPsoilmoisture%…Davis VP soil moisture
%VPsoilmoisture2%…Davis VP soil moisture, # 2 sensor
%VPsoilmoisture3%…Davis VP soil moisture, # 3 sensor
%VPsoilmoisture4%…Davis VP soil moisture, # 4 sensor
%VPsoiltemp2%…Davis VP soil temperature #2
%VPsoiltemp3%…Davis VP soil temperature #3
%VPsoiltemp4%…Davis VP soil temperature #4
%VPextratemp1%…Davis VP extra temperature #1
%VPextratemp2%…Davis VP extra temperature #2
%VPextratemp1hi%…Davis VP extra temp 1 daily high
%VPextratemp1lo%…Davis VP extra temp 1 daily low
%VPextratemp2hi%…Davis VP extra temp 2 daily high
%VPextratemp2lo%…Davis VP extra temp 2 daily low
%VPextratemp3hi%…Davis VP extra temp 3 daily high
%VPextratemp3lo%…Davis VP extra temp 3 daily low
%VPextratemp4hi%…Davis VP extra temp 4 daily high
%VPextratemp4lo%…Davis VP extra temp 4 daily low
%VPextrahum1%…Davis VP extra humidity #1
%VPextrahum2%…Davis VP extra humidity #2
%VPleaf%…Davis VP leaf wetness
%VPleaf2%…Davis VP leaf wetness, # 2 sensor
%VPleaf3%…Davis VP leaf wetness, # 3 sensor
%VPleaf4%…Davis VP leaf wetness, # 4 sensor
%hiVPleaf%…Davis VP leaf wetness, daily high (#1 sensor)
%loVPleaf%…Davis VP leaf wetness, daily low
%hiVPleaf2%…Davis VP leaf wetness, daily high (#2 sensor)
%loVPleaf2%…Davis VP leaf wetness, daily low
%hiVPsoilmoisture%…Davis VP soil moisture, daily high
%loVPsoilmoisture%…Davis VP soil moisture, daily low
%hiVPsoilmoisture2%…Davis VP soil moisture, daily high #2
%loVPsoilmoisture2%…Davis VP soil moisture, daily low #2
%hiVPsoilmoisture3%…Davis VP soil moisture, daily high #3
%loVPsoilmoisture3%…Davis VP soil moisture, daily low #3
%hiVPsoilmoisture4%…Davis VP soil moisture, daily high #4
%loVPsoilmoisture4%…Davis VP soil moisture, daily low #4%hiVPsoiltemp2%…Davis VP soil temp, daily high. # 2 sensor
%loVPsoiltemp2%…Davis VP soil temp, daily low, # 2 sensor
%hiVPsoiltemp3%…Davis VP soil temp, daily high, # 3 sensor
%loVPsoiltemp3%…Davis VP soil temp, daily low, # 3 sensor
%hiVPsoiltemp4%…Davis VP soil temp, daily high, # 4 sensor
%loVPsoiltemp4%…Davis VP soil temp, daily low, # 4 sensor
Chuck
Thanks Chuck. I’m able to get the values but there does not seem to be tags for the times the daily high or low occurred.
Bill
Okay gotcha. Try putting them under a suggestions to see if Brain will add those tags.
Chuck
