Table probl
I am using the custom settings as per Brian because of that crashing thing.
Everything seems to be working, but the following table has stopped updating. I have looked and think everything is fine. What else do I need to look for?
http://home.mchsi.com/~weatherdata/myweather.html
looks like you got this sorted?
(i.e would have been a remote file name issue?)
so is wd behaving itself now for you?
right now it is. but the summary.jpg doesn’t update. So I took that off and somehow it all sorts out. I went through the custom update/load and hit set on all that applied and that works.
I get the screen image of summary.jpg but it doesn’t update . No big difference, I think there exists enough options to tell the conditions .
it might be that it should be summary.gif as the remote file name, if you do not have ticked to use .jpg in the summary image and icon setup
check that
but otherwise no more crashes?
so far no more crashes. ( as I turn blue holding my breath).
I do notice some little quirks ( I think they make nice Pets) I have noticed things such as FWI.htm; dailyreport.htm; dailynoaareport.htm updates, but doesn’t upload to the site . So… I do a manual upload and we are fine.
I wonder how much trouble I would be in if I had the FWI.htm upload one time after 1 pm; the dailyreport and daily noaa upload after midnight using the General FTP option. I used that when they didn’t load normally before. Not sure why they don’t upload, they didn’t upload before I used the custom settngs. But everything else works. and I can live with that.
there is a place in the customise setup to set times to create and upload those files …try that
