On my display however, the high temp and low temp are reversed… and, oddly, the numbers shown for high and low of the day are different than the ones the main WD program is displaying…??
My high & low temps are fine. Actual temp 41F feels like 121F http://www.shermanctweather.com/svg.htm
It seems that the higher the actual temp the lower the feels like temp.
This is a very nice feature and a graet addition.
maybe, try setting a station name , in the real time setup, for the clienraw file, under seup, webfiles/web page setup, real me ftp
a new 9.95 now adds the time next to that station name you set there too
and i have added a ftp reset
glad you guys like it and got it going
now WD finally has a real time viewer!
I just downloaded the newest WD… made sure I had the correct items checked in setup and took a look at my svg display… the low in my display seems to show the high, the high seems to show a value that is not my low… looks to be maybe the heat index…
I just loaded the latest WD. Right after my high temp and low temp are switched. You can see this at http://www.shermanctweather.com/svg.htm
Also still have too high of a real feel temp.
Not to add trouble to trouble, but my baro trend is falling, but the real-time display shows that it is rising!
Weird day here, fires have put so much smoke in the air that there is a red/yellow tint to everything… almost like wearing sunglasses… weird… but then 100 F in late October is weird too!
i carefully counted
up to the station name, they both have the same numbers
greg, for the numbers to be around the wrong way, the high/low, being out of sync in the sequence would not do that…yes/no?"
i have it
i add the time to the end of the station name
but it depends on your windows settings
and some have the PM or AM added to the end, which puts in a space
thats the reason for it being out of sync
I will add a - where that space is!
and that is why the heat index is wrong too
uploaidng a new 9.95 now, will let you know when ready
I am using the latest version of WD… I did have 1-wire sensors in my setup at one point, they are still there, but I don’t use them any more… in fact my SVG display shows the solar reading (0%)…
Let me know if I can be of any help to any of you bug squishers!
we crossed posts stuntman
i have tracked it down to a AM or PM appearing in the windows time stamp
i have fixed that, uploading a bew 9.995, will let you know when ready to download
I don’t think the feels like temp that is calculated locally in main.svg is working very well… Is there a heat index value or something in the clientraw.txt that I could use directly?
