Would it be possible to allow WD to display the output of the Temp sensor on the temp/humid probe?
ok, doing this now, and uploading a new zip verison update
it will be available in wd as the dallashumtemp4
(i.e for custom tag)
I have one question though, where can I view the reading. I looked but I don’t see a dallashumtemp4 under any of the extra sensor pages. I also looked under the dallas 1 wire setup, but did not see this sensor number either.
under setup,labjack setup, view the readings, it will show there
you should be able to use the custom tag for the dallashumtemp4 (i think!)
