Sunshine Hours
How are the Sunshine Hours calculated in WD?
its explained in my (still adding to) help file:
http://www.weather-display.com/WDHELP.doc
in the solar section
but basicly when the solar reading % is above the sunny threshold you have set in the solar setup (default is 85%) then WD adds sunshine hours (actualy minutes)
Brian,
maybe I hve a problem with the sunshine-hours
Before midday t seems to be not enough hours and after midday to much hours, i.e. the readings from my VP solar are high, but WD thinks not high enough and the other way round.
I have set my lat/long and latitude.
Maybe a problem with the european summertime settings?
Peter
tick daylight saving in use in the solar setup, next to the use max solar radiation for …
Oh, now I know what “daylight saving” means…
Peter
