Brian
Would it be possible to add U/V numbers to this graph also. You might also consider putting the date in the log file so if we miss data we can add it back in proper place. Is this file data backed up in your “Data Back Up” utility?
Brian
you can add missing data, via the , say, 92004lgsun.txt file …
i dont have UV stored there,…but it is in the vp log file…hummm
I meant to add u/v numbers to your graph and pull the u/v numbers into your lgsun file from the vplog. It would be neat to see at a glance the see the high sunshine hours, u/v, and maybe even w/m2. I really like that graph.
Ah, also ET, would be nice
please
Cheers
Cyclone
ok, i have added a 2nd graph for max solar/ max UV
and the first graph has ET on it now
in a new 10.17x, uploading now
ok, i have added a 2nd graph for max solar/ max UV and the first graph has ET on it nowWhat are the filenames , windy? Cheers Cyclone
the 102004vantagelog.txt
contains the solar and UV
and so WD is pulling the max values from that for each day…
Looks great, many cheers
