Sunset is always at 00:00?
Sorry - but another problem for me - and I do not understand why.
Normaly - on the graph in the main-window of Weather-Display (12 hour graph) - shouldn’t be there the words sunset and sunrise? I do not see them on my main-window - as you can see here
Also - on my website in the picture for the last 24 hours - the sunset is always on 00:00 - when all datas get their reset - hmm - the sunrise is not appearing - never. But of course - as you can see at the sunmoon picture - the times for the sunrise and sunset are not at 00:00. So please again - can someone tell me what is wrong here? Thx again!
Here you can see - the sunset is at 00:00
Here are the correct times for my sunrise and sunset…
Have you set up your lat/lon - sun/moon settings?
Under setup > control panel > sun/moon-lat/lon
you need to enter your location settings
(I learned this the same way - by asking here!)
Windows time zone too…
yes, make sure your lat/long are set correct (and check you dont have them back to front), and yes, check that your windows time zone is correct too
Ok - Thx for your help. Here a “update” for you…
My Lat/Long are ok - also my time and my timezone.
You can see this here:
After I have changed this option here
[Sunmoon]
day all time=no
per hand in the WDisplay.ini file - I have now a sunrise and a sunset - and yes - not at 00:00 - nearly correctly when the times are…
I have found out -
when I use the 3 hour graph in the main window of weather-display - the sunset and sunrise are correct in the graph - at the times which are shown at my sunmoonimage and in the sunmoon-setup for me - everything is ok.
The same counts for the 6 hour graph in the main-window of weather display - everything is ok.
To the 12 hour graph - which I use normaly.
Now I have a sunrise and a sunset - but 2 hours too late. For example - when the sunrise is for me at 6:00 - the 12 hour graph shows it for me at 8:00. Example for the sunset - the sunset is for me at 21:00 - the graph shows 23:00.
Does anybody know why the 3 hour and 6 hour graphs are correct - but the 12 hour graph is wrong? I do not understand it - sorry.
The same counts for the 24 hour graph - the times are I think 1 hour wrong. Very myterious in my eyes.
So - if anybody knows - please tell me - Thank you!
But at least - the 3 hour and 6 hour graphs work…a little bit success at least.
Stephan
