Summary.gif condition image
OK I know I’m a newbie and it’s probably something I’m doing wrong but… :? the current conditions image that comes up in the summary.gif file keeps changing to Haze and then it stays that way. I have tried clicking the default in the image page and that corrects it for a short while, a few hours, but it keeps going back.
So I guess my question is what am I doing wrong? I know I live in Massachusetts but it really isn’t hazy all the time.
:slight_smile:
Here is the link so you can see what I mean:
http://home.comcast.net/~phixer/
have you tried changing the temp threshold for haze, in the summary image and icon setup?
or even try loading a new icon for haze, in the input daily weather?
Tired setting temp to 1c and humidity to 0%, then tried setting temp to 50c and humidity to 100% with no luck. I had previously adjusted the humidity up two points using the offset setup but I don’t think that would cause the problem. I think I’ll try ??? installing the latest version of WD and see if the fixes the problem.
Oh yeah I forgot to ask. Shouldn’t the iocn on the summary match the one on current conditions? :?:
yes, it should…
email me your settings files:
go action, back up registry entry now, then email me the files wdisplayftp.reg and wdisplay.ini from the folder databackup
Brian,
I emailed the files to you on Sunday. Been playing with the settings and I found if I set it to use the WMR-968 to update the icons both summary and current icons match. Now that I have set it back and the Haze icon is gone but summary and current don’t match. Very strange, maybe my computer has lost it’s mind. (maybe I have, who knows)
Thanks for looking at this.
Ken
oh, ok
(i get 100’s of emails, its hrd to keep up at times)
Brian,
That did the trick. Thanks for the help.
:slight_smile: :smiley:
