I would down the road like to see the xml file be more flexable,
Say I would want to disable(remove windchill graph during spring and summer) and have the highs and low ^ v temp be displayed with the
heat index chart.
Another feature in the drop down menu to open a small popup box containing
your own link to a web cam you may have.(as long as it doesnt increase the
swf file that much.
Otherwise job well done…
Sean
Me too! It could be very flexible but the difficulty is making the configuration easy. For example if you didn’t want the windchill thermometer you’d probably want to rearrange the other dials and gauges to balance the look of the display. This could be done with the config file by entering co-ordinates but you really need a nice GUI to make it easy. Long term it may need another application (which you install on your PC) which you use to arrange the layout of the dials and then use it to generate the xml file. In the short term I plan to offer more options in the config file with a limited choice in the placement of the dials.
Second, you are right, it will probably need some kind of fancy front-end to move and play with re-arrainging the dials, etc. A long range change.
Third, and possibly an unpopular suggestion…
I use another product, Album-Express. It’s a shareware product also from your side of the pond. He just raised the US price because of the weak US Dollar. You really deserve more than $20 US for this. Considering what it has done for my weather web page. Sometimes, I just load up WDL and leave it run on a second monitor so I can watch the pretty dials spin :happy3:
