Stored ftp settings [Resolved]
Been a while since I’ve been on the forum.
My main computer crashed a couple weeks ago. And I’m trying to put Weather Display on a different computer.
Davis Vantage Weather Station.
Are the ftp settings stored anywhere? I’m trying to recreate what I have without access to the crashed computer but not having much luck in remembering how I set it up. I do have backup. And access to the settings files but I can’t find how I set up the upload site.
Linda
Not sure how much of this FAQ you can follow. . .
in your backup look for the databackup folder
then look for the first 3 files if you have all three then with WD not running copy the ini file to main WD folder and double click the reg file to install the reg file these 2 files contain all you setting
if only the zip file is there unzip and the same 2 files should be in there
Thanks. Got it working. Registry was the big key.
Linda
Thanks, big key was the Registry file.
Linda
