Understood, but it just ‘looks’ better.
My main site page displays mph in tenths (Davis VP2+ with Scott’s alt dashboard), so it’s getting it from somewhere. Will have to dig into that code and see where it’s coming from.
Have a look in your ccr file, is it in tenths there, if not then the tag may be the problem.
Don’t forget that the initial page load wind data loaded from the clientraw.txt will have been converted from knots, so it’s likely to have decimals in mph, and any calculated average will also result in decimals.
“wspeed”:“%avgspd%” passes a decimal - “wspeed”:“5.6”. The other wind items are all “x.0”. I assume function doWind() needs a little massage, but that is beyond my knowledge (much is these days).
Thoughts appreciated.
Understood.
Thanks, niko.
the averaging produces the decimal place
(it could be argued if that should be like that or not)
there are tags with no decimal from memory
wspeed = 10 minute average windspeed = green sector on gauge
wlatest = latest wind speed reading = gauge needle & digital readout
So as Brian says the 10 minute average is calculated to one decimal place which makes sense to me, but the readings from your station are in 1 mph increments.
Mark,
0.11.4 will not unpack for me. Downloaded twice, but it just locks up my unzipper.
Thank you! That was exactly the definition this old mind needed.
Now to dig into the tags list.
John, for some reason the forum does not like my zip files, I have created it using two different software (WinZip & Windows Explorer), and whilst both files look the correct size, they have zero files listed in the contents when you download them again. I have uploaded the same file to the Cumulus forum and it works fine. So I am at a bit of a loss now. ](*,)
But it downloaded fine for me and runs great. :dontknow:
Jim, could you try and download and open it again now for me please, both the computers I have powered on at the moment say it is corrupt when I download it.
Mark,
Sure thing, just did and opened both files with UltraEdit and they look just fine here.
Weird, I wonder if there is a corrupt copy cached somewhere?
Mark,
Jim kindly sent me a copy of his and it worked fine.
Mark,
Keep forgetting to ask this. Inside /scripts/ is another /scripts/. The first has all the needed goodies, and the second contains only another copy of steelseries.js. Is it really needed?
Downloaded and upzipped just fine for me, too. No problems whatsoever.
-Keith
Nope, that was included by error. I’ll clean everything up for the next release.
Tank U!
