It is Weather Display for Linux console 64 bit Linux desktop Version on 15 February 2019.
that is the info I have been looking for
I will check/test and get back to you
took me a while as I had problems with my linux setup
anyway, try this update
http://www.weather-display.com/downloadfiles/consolewd64desktop.tar.gz
it looks like it is working now. Thank you very much.
In another subject. Would it be possible to add UV-Index as an input value in the datain38.ini and universal weather station type (#34)?
Thank you for your support
Urs
I guess I can do that OK, yes
post here your current datain38.ini file
current datain38.ini is:
6.02 3.300 7.6 67 949 272.58 40 0.0 24.3 44 89
I will see what I can do today and let you know
added that now (i.e add after solar)
I did download and install. The problem is that with the latest version consolewd does no longer ftp:
Current data 19:37:55: Temperature= 8.2 Windspeed =6.1 Gustspeed =11.1 Direction =195 Humidity=86 Barometer=952.0 Daily Rain=0.9 Rain Rate 0.0mm/min
Data OK
Current data 19:37:58: Temperature= 8.2 Windspeed =6.1 Gustspeed =11.1 Direction =195 Humidity=86 Barometer=952.0 Daily Rain=0.9 Rain Rate 0.0mm/min
**** doing minute routines now 19:38:00
**** updating clientraw extra files
**** updating data logs
** opening custom input file /volume1/web/home/consolewdfiles/wxlocal.html
***closed custom tag in file
******custom output 1 /volume1/web/home/consolewdfiles/wx.html
******re writing custom file
**custom tags lines to write 1
** closed custom tag out file
Killing cronftpreal
cronftpreal: no process found
Starting cronftpreal
updating records to ini file
Time 60 seconds
Remote name
Port to use 21
Could not open
Connection failed waiting 5 minutes
Data OK
Current data 19:38:02: Temperature= 8.2 Windspeed =6.1 Gustspeed =11.1 Direction =195 Humidity=86 Barometer=952.0 Daily Rain=0.9 Rain Rate 0.0mm/min
Data OK
Current data 19:38:05: Temperature= 8.2 Windspeed =6.1 Gustspeed =11.1 Direction =195 Humidity=86 Barometer=952.0 Daily Rain=0.9 Rain Rate 0.0mm/min
Data OK
Any help to this?
if you have the previous version then try using the cronftpreal from that version?
no - I don’t have a previous version.
I am still trying to figure out a solution to my problem.
The information from clientraw.txt is: CWD_console_17.9
If I do run ./cronftpreal from the command line it works. But it still does not if it is run as part of ./consolewd.
Is there a log template I could use to find out more about what is not working correctly?
Any help to this?
I am away at a conference for
A couple of days
But will look at this when I get back
One thing
Try running consolewd as sudo
I will do some testing/checking today and see what I can find out
Thank you very much for testing.
I did sudo ./consolewd and it did not make a difference.
Is there a logfile template I could use to find out more?
in testing here
if I run as sudo ./consolewd
then cronftpreal is not able to read in the wdconsole.ini settings
i.e so no ftp server info read in
but if I ran as
./consolewd only it was able to
so its a problem with the wdconsole.ini settings permissions
try a new update
i have made a change to the ini file that seems to help
Thank you very much. It is working now!
