Hello,
Why the status message (dry, rain, snow) do not change?
Bye
Hello,
Bye
Is it only the current conditions message that doesn’t change?
Are you using Metar for the web conditions?
Does what is displayed correspond to the information in the clientraw.txt file that you upload to the webserver?
I don’t use the data of the metar…
The same problem there is in swg display mode.
Sometimes work…
The file is created of the program.
:roll:
It sounds like it’s the output from WD in that case rather than WDL.
Hello, Why the status message (dry, rain, snow) do not change?That information may be determined by how the WD Summary image/icons is set up (Fog, Windspeed, Rain). This page may help: http://www.tokaanuskihire.co.nz/wdhelp/summarysetup.shtmlBye
These threads may also help: http://www.weather-watch.com/smf/index.php?topic=2887.0 http://www.weather-watch.com/smf/index.php?topic=3115.0 http://www.weather-watch.com/smf/index.php?topic=3117.0...Why the status message (dry, rain, snow) do not change?....That information may be determined by how the WD Summary image/icons is set up (Fog, Windspeed, Rain). This page may help: http://www.tokaanuskihire.co.nz/wdhelp/summarysetup.shtml
Some of my Summary Image settings may be extreme but you may view them at:
http://littleswitzerlandweather.info/img/summarysetup.jpg
I do use the METAR update for some values.
