Station setup
Since I once tried “listen to the data only” for a VP station I see this every time when I start up the software. So the software is not losing this setting even when I exit and save the software with the normal 19200 baudrate setting. Why did I tried that? I do not know.
so when I start the software again the dat of the VP will not be used unless I change that setting.
WD 17f
windows xp
vp weather station, not a rev B ( i was too early with buying this station and moved to Holland)
ah, i need to fix that
that is a setting so that you can have wd work as a piggy back with another software…
uploading a fix now as 10.17g :wink:
thanks a lot, will try the update.
