Startup in Vista Problem
When I start WD I get a “User Account Control” window, saying that an unidentified program wants to run–cancel or allow? I have set the privilege level–"Run this program as an administrator "and “Run this program in compatibility mode”, etc (per a FAQ). I should be able to start up directly, you think?? Any solution (besides going back to Win XP)?
Thanks, Richard
Is there a check box that says “remember this action” - if so check that box. This happens if you unzip the main exec into the WD folder, rather than install the full version.
Craig
