as i though, setting the program to a actaul davis VP, 0.01 inch rain setting, and the rain total was 0.14 inches, not 1.4 inches, as nikoshepered suspected, it was out by a factor of 10 out
But if I add up the values in the vptemplog I get 60.5mm = 2.38", or allowing for the factor of 10 0.238" which is about right compared to wlink.i did not get that total nikoshepared...?
here is WD’s log file for a test of the raw data import
(the rain last minute is working but for some reason the daily and monthly and yearly are not increasing at all ( i will check on that now)
day month year hour minute temperature humidity dewpoint barometer windspeed gustspeed direction rainlastmin dailyrain monthlyrain yearlyrain heatindex
19 5 2005 18 38 81.2 62 66.9 29.831 5 6 22 0.000 0.000 0.000 10.789 83.6
19 5 2005 18 39 81.2 63 67.4 29.831 3 8 45 0.000 0.000 0.000 10.789 83.8
19 5 2005 18 40 81.2 63 67.4 29.831 6 8 45 0.000 0.000 0.000 10.789 83.8
19 5 2005 18 41 81.2 63 67.4 29.831 3 8 45 0.000 0.000 0.000 10.789 83.8
19 5 2005 18 42 81.2 63 67.4 29.831 3 7 45 0.000 0.000 0.000 10.789 83.8
19 5 2005 18 43 81.2 63 67.4 29.831 3 8 135 0.000 0.000 0.000 10.789 83.8
19 5 2005 18 44 81.2 62 66.9 29.831 3 6 90 0.000 0.000 0.000 10.789 83.6
19 5 2005 18 45 81.2 63 67.4 29.831 3 6 45 0.000 0.000 0.000 10.789 83.8
19 5 2005 18 46 81.2 63 67.4 29.831 3 7 45 0.000 0.000 0.000 10.789 83.8
19 5 2005 18 47 81.1 62 66.8 29.831 3 10 112 0.000 0.000 0.000 10.789 83.5
19 5 2005 18 48 81.1 62 66.8 29.831 3 8 22 0.000 0.000 0.000 10.789 83.5
19 5 2005 18 49 80.9 63 67.1 29.831 3 6 68 0.000 0.000 0.000 10.789 83.4
19 5 2005 18 50 80.9 63 67.1 29.831 3 7 22 0.000 0.000 0.000 10.789 83.4
19 5 2005 18 51 80.7 63 66.9 29.831 7 10 45 0.000 0.000 0.000 10.789 83.1
19 5 2005 18 52 80.5 63 66.7 29.831 3 7 22 0.000 0.000 0.000 10.789 82.8
19 5 2005 18 53 80.5 63 66.7 29.831 3 6 68 0.000 0.000 0.000 10.789 82.8
19 5 2005 18 54 80.3 63 66.6 29.831 2 3 45 0.000 0.000 0.000 10.789 82.5
19 5 2005 18 55 80.3 63 66.6 29.831 5 6 45 0.000 0.000 0.000 10.789 82.5
19 5 2005 18 56 80.3 63 66.6 29.831 3 7 45 0.000 0.000 0.000 10.789 82.5
19 5 2005 18 57 80.1 63 66.4 29.831 3 6 45 0.000 0.000 0.000 10.789 82.3
19 5 2005 18 58 80.1 64 66.8 29.831 3 7 45 0.000 0.000 0.000 10.789 82.4
19 5 2005 18 59 80.1 64 66.8 29.831 1 2 45 0.000 0.000 0.000 10.789 82.4
19 5 2005 19 0 79.9 64 66.6 29.836 5 8 45 0.000 0.000 0.000 10.789 82.1
19 5 2005 19 1 79.9 64 66.6 29.836 3 7 68 0.000 0.000 0.000 10.789 82.1
19 5 2005 19 2 79.9 64 66.6 29.836 2 6 45 0.000 0.000 0.000 10.789 82.1
19 5 2005 19 3 79.9 64 66.6 29.836 3 6 45 0.000 0.000 0.000 10.789 82.1
19 5 2005 19 4 79.8 64 66.5 29.836 3 6 45 0.000 0.000 0.000 10.789 82.0
19 5 2005 19 5 79.8 64 66.5 29.836 1 2 45 0.000 0.000 0.000 10.789 82.0
19 5 2005 19 6 79.8 64 66.5 29.836 2 3 0 0.000 0.000 0.000 10.789 82.0
19 5 2005 19 7 79.8 64 66.5 29.836 3 8 68 0.000 0.000 0.000 10.789 82.0
19 5 2005 19 8 79.8 64 66.5 29.836 3 8 45 0.000 0.000 0.000 10.789 82.0
19 5 2005 19 9 79.8 64 66.5 29.836 3 8 45 0.000 0.000 0.000 10.789 82.0
19 5 2005 19 10 79.6 65 66.8 29.836 3 6 45 0.000 0.000 0.000 10.789 81.8
19 5 2005 19 11 79.6 65 66.8 29.836 1 2 90 0.000 0.000 0.000 10.789 81.8
19 5 2005 19 12 79.6 65 66.8 29.836 3 3 22 0.000 0.000 0.000 10.789 81.8
19 5 2005 19 13 79.6 65 66.8 29.836 3 8 68 0.000 0.000 0.000 10.789 81.8
19 5 2005 19 14 79.6 65 66.8 29.836 5 12 22 0.000 0.000 0.000 10.789 81.8
19 5 2005 19 15 79.6 65 66.8 29.840 6 10 68 0.000 0.000 0.000 10.789 81.8
19 5 2005 19 16 79.6 65 66.8 29.840 3 5 68 0.000 0.000 0.000 10.789 81.8
19 5 2005 19 17 79.4 65 66.6 29.840 3 8 68 0.000 0.000 0.000 10.789 81.6
19 5 2005 19 18 79.4 66 67.0 29.840 3 7 22 0.000 0.000 0.000 10.789 81.6
19 5 2005 19 19 79.4 66 67.0 29.840 5 8 45 0.000 0.000 0.000 10.789 81.6
19 5 2005 19 20 79.4 66 67.0 29.840 2 5 68 0.000 0.000 0.000 10.789 81.6
19 5 2005 19 21 79.4 66 67.0 29.840 5 12 22 0.000 0.000 0.000 10.789 81.6
19 5 2005 19 22 79.4 66 67.0 29.840 2 6 0 0.000 0.000 0.000 10.789 81.6
19 5 2005 19 23 79.2 66 66.9 29.840 5 8 45 0.000 0.000 0.000 10.789 81.4
19 5 2005 19 24 79.2 66 66.9 29.840 5 6 112 0.000 0.000 0.000 10.789 81.4
19 5 2005 19 25 79.2 66 66.9 29.840 2 3 90 0.000 0.000 0.000 10.789 81.4
19 5 2005 19 26 79.0 67 67.1 29.840 2 3 68 0.000 0.000 0.000 10.789 81.2
19 5 2005 19 27 79.0 67 67.1 29.840 3 6 45 0.000 0.000 0.000 10.789 81.2
19 5 2005 19 28 79.0 67 67.1 29.840 3 5 22 0.000 0.000 0.000 10.789 81.2
19 5 2005 19 29 79.0 67 67.1 29.840 3 6 90 0.000 0.000 0.000 10.789 81.2
19 5 2005 19 30 78.8 67 66.9 29.846 1 3 45 0.000 0.000 0.000 10.789 80.9
19 5 2005 19 31 78.8 67 66.9 29.846 0 1 45 0.000 0.000 0.000 10.789 80.9
19 5 2005 19 32 78.8 67 66.9 29.846 0 1 45 0.000 0.000 0.000 10.789 80.9
19 5 2005 19 33 78.8 67 66.9 29.846 0 1 45 0.000 0.000 0.000 10.789 80.9
19 5 2005 19 34 78.8 67 66.9 29.846 0 3 45 0.000 0.000 0.000 10.789 80.9
19 5 2005 19 35 78.8 67 66.9 29.846 3 3 22 0.000 0.000 0.000 10.789 80.9
19 5 2005 19 36 78.8 67 66.9 29.846 2 6 0 0.000 0.000 0.000 10.789 80.9
19 5 2005 19 37 78.8 67 66.9 29.846 2 6 68 0.000 0.000 0.000 10.789 80.9
19 5 2005 19 38 78.8 68 67.3 29.846 3 6 112 0.000 0.000 0.000 10.789 81.0
19 5 2005 19 39 78.6 68 67.2 29.846 3 5 45 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 40 78.6 68 67.2 29.846 2 6 68 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 41 78.6 68 67.2 29.846 3 6 45 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 42 78.6 68 67.2 29.846 3 9 45 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 43 78.6 68 67.2 29.846 2 3 45 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 44 78.6 68 67.2 29.846 2 6 45 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 45 78.6 68 67.2 29.846 3 5 45 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 46 78.6 68 67.2 29.846 2 3 22 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 47 78.6 68 67.2 29.846 3 7 90 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 48 78.6 68 67.2 29.846 2 3 45 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 49 78.6 68 67.2 29.846 3 3 45 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 50 78.6 68 67.2 29.846 1 3 22 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 51 78.6 68 67.2 29.846 1 3 22 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 52 78.6 68 67.2 29.846 3 6 45 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 53 78.6 68 67.2 29.846 1 3 45 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 54 78.5 69 67.5 29.846 1 2 68 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 55 78.5 69 67.5 29.846 2 5 68 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 56 78.5 69 67.5 29.846 3 8 22 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 57 78.5 69 67.5 29.846 3 8 45 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 58 78.5 69 67.5 29.846 5 7 45 0.000 0.000 0.000 10.789 80.7
19 5 2005 19 59 78.5 69 67.5 29.846 2 3 45 0.000 0.000 0.000 10.789 80.7
19 5 2005 20 0 78.3 69 67.3 29.849 3 6 45 0.000 0.000 0.000 10.789 80.4
19 5 2005 20 1 78.3 69 67.3 29.849 5 8 45 0.000 0.000 0.000 10.789 80.4
19 5 2005 20 2 78.3 69 67.3 29.849 3 6 45 0.000 0.000 0.000 10.789 80.4
19 5 2005 20 3 78.3 69 67.3 29.849 6 8 45 0.000 0.000 0.000 10.789 80.4
19 5 2005 20 4 78.3 69 67.3 29.849 3 6 45 0.000 0.000 0.000 10.789 80.4
19 5 2005 20 5 78.3 69 67.3 29.849 1 3 45 0.000 0.000 0.000 10.789 80.4
19 5 2005 20 6 78.3 69 67.3 29.849 3 3 45 0.000 0.000 0.000 10.789 80.4
19 5 2005 20 7 78.3 70 67.7 29.849 3 10 22 0.000 0.000 0.000 10.789 80.4
19 5 2005 20 8 78.3 70 67.7 29.849 2 3 68 0.000 0.000 0.000 10.789 80.4
19 5 2005 20 9 78.3 70 67.7 29.849 3 6 45 0.000 0.000 0.000 10.789 80.4
19 5 2005 20 10 78.1 70 67.5 29.849 3 7 22 0.000 0.000 0.000 10.789 80.2
19 5 2005 20 11 78.1 70 67.5 29.849 3 7 0 0.000 0.000 0.000 10.789 80.2
19 5 2005 20 12 78.1 70 67.5 29.849 6 10 45 0.000 0.000 0.000 10.789 80.2
19 5 2005 20 13 78.1 70 67.5 29.849 2 3 22 0.000 0.000 0.000 10.789 80.2
19 5 2005 20 14 78.1 70 67.5 29.849 3 8 45 0.000 0.000 0.000 10.789 80.2
19 5 2005 20 15 78.1 70 67.5 29.852 5 10 68 0.000 0.000 0.000 10.789 80.2
19 5 2005 20 16 78.1 70 67.5 29.852 2 3 68 0.000 0.000 0.000 10.789 80.2
19 5 2005 20 17 78.1 70 67.5 29.852 2 3 68 0.000 0.000 0.000 10.789 80.2
19 5 2005 20 18 78.1 70 67.5 29.852 3 6 45 0.000 0.000 0.000 10.789 80.2
19 5 2005 20 19 78.1 70 67.5 29.852 3 6 45 0.000 0.000 0.000 10.789 80.2
19 5 2005 20 20 78.1 71 67.9 29.852 0 1 45 0.000 0.000 0.000 10.789 80.2
19 5 2005 20 21 78.1 71 67.9 29.852 2 7 68 0.000 0.000 0.000 10.789 80.2
19 5 2005 20 22 78.1 71 67.9 29.852 6 12 135 0.000 0.000 0.000 10.789 80.2
19 5 2005 20 23 77.9 71 67.7 29.852 5 10 90 0.000 0.000 0.000 10.789 79.9
19 5 2005 20 24 77.9 73 68.5 29.852 2 5 135 0.000 0.000 0.000 10.789 80.0
19 5 2005 20 25 77.7 73 68.4 29.852 3 6 90 0.000 0.000 0.000 10.789 79.7
19 5 2005 20 26 77.6 73 68.3 29.852 2 3 45 0.000 0.000 0.000 10.789 79.5
19 5 2005 20 27 77.6 74 68.7 29.852 2 3 68 0.000 0.000 0.000 10.789 79.6
19 5 2005 20 28 77.4 75 68.9 29.852 2 3 112 0.000 0.000 0.000 10.789 79.3
19 5 2005 20 29 77.4 75 68.9 29.852 1 5 112 0.000 0.000 0.000 10.789 79.3
19 5 2005 20 30 77.2 76 69.0 29.861 3 7 90 0.000 0.000 0.000 10.789 79.0
19 5 2005 20 31 77.0 76 68.9 29.861 3 7 90 0.000 0.000 0.000 10.789 78.7
19 5 2005 20 32 76.8 76 68.7 29.861 6 10 112 0.000 0.000 0.000 10.789 78.4
19 5 2005 20 33 76.7 77 68.9 29.861 2 5 90 0.000 0.000 0.000 10.789 78.2
19 5 2005 20 34 76.5 79 69.5 29.861 2 5 90 0.000 0.000 0.000 10.789 77.8
19 5 2005 20 35 76.3 79 69.3 29.861 1 3 112 0.000 0.000 0.000 10.789 77.5
19 5 2005 20 36 76.3 80 69.7 29.861 3 7 90 0.000 0.000 0.000 10.789 77.5
19 5 2005 20 37 76.1 80 69.5 29.861 2 3 90 0.010 0.000 0.000 10.789 77.1
19 5 2005 20 38 76.0 80 69.4 29.861 3 12 112 0.000 0.000 0.000 10.789 77.0
19 5 2005 20 39 75.8 81 69.6 29.861 3 7 135 0.020 0.000 0.000 10.789 76.6
19 5 2005 20 40 75.6 81 69.4 29.861 3 7 90 0.000 0.000 0.000 10.789 76.3
19 5 2005 20 41 75.3 81 69.1 29.861 2 6 45 0.000 0.000 0.000 10.789 75.9
19 5 2005 20 42 74.9 82 69.0 29.861 1 3 45 0.010 0.000 0.000 10.789 75.2
19 5 2005 20 43 74.7 82 68.8 29.861 2 3 68 0.000 0.000 0.000 10.789 74.9
19 5 2005 20 44 74.6 83 69.1 29.861 2 3 112 0.000 0.000 0.000 10.789 74.6
19 5 2005 20 45 74.4 84 69.2 29.862 1 3 112 0.000 0.000 0.000 10.789 74.1
19 5 2005 20 46 74.2 84 69.1 29.862 2 3 68 0.000 0.000 0.000 10.789 73.9
19 5 2005 20 47 74.0 84 68.9 29.862 1 1 68 0.000 0.000 0.000 10.789 73.6
19 5 2005 20 48 74.0 84 68.9 29.862 2 3 90 0.000 0.000 0.000 10.789 73.6
19 5 2005 20 49 73.9 84 68.8 29.862 1 2 112 0.000 0.000 0.000 10.789 73.4
19 5 2005 20 50 73.9 84 68.8 29.862 0 1 112 0.000 0.000 0.000 10.789 73.4
19 5 2005 20 51 73.7 85 68.9 29.862 1 3 90 0.000 0.000 0.000 10.789 73.0
19 5 2005 20 52 73.7 85 68.9 29.862 1 1 90 0.000 0.000 0.000 10.789 73.0
19 5 2005 20 53 73.7 85 68.9 29.862 1 2 90 0.000 0.000 0.000 10.789 73.0
19 5 2005 20 54 73.7 85 68.9 29.862 0 1 90 0.000 0.000 0.000 10.789 73.0
19 5 2005 20 55 73.5 86 69.1 29.862 0 1 90 0.000 0.000 0.000 10.789 72.5
19 5 2005 20 56 73.5 86 69.1 29.862 1 2 90 0.000 0.000 0.000 10.789 72.5
19 5 2005 20 57 73.5 86 69.1 29.862 1 1 90 0.000 0.000 0.000 10.789 72.5
19 5 2005 20 58 73.5 86 69.1 29.862 0 1 90 0.010 0.000 0.000 10.789 72.5
19 5 2005 20 59 73.5 86 69.1 29.862 1 2 90 0.000 0.000 0.000 10.789 72.5
19 5 2005 21 0 73.5 87 69.4 29.865 2 3 90 0.000 0.000 0.000 10.789 72.2
19 5 2005 21 1 73.5 87 69.4 29.865 2 2 112 0.000 0.000 0.000 10.789 72.2
19 5 2005 21 2 73.5 87 69.4 29.865 1 5 112 0.000 0.000 0.000 10.789 72.2
19 5 2005 21 3 73.5 87 69.4 29.865 3 5 158 0.010 0.000 0.000 10.789 72.2
19 5 2005 21 4 73.3 87 69.2 29.865 3 6 112 0.000 0.000 0.000 10.789 71.9
19 5 2005 21 5 73.3 87 69.2 29.865 5 8 112 0.000 0.000 0.000 10.789 71.9
19 5 2005 21 6 73.3 87 69.2 29.865 2 3 135 0.000 0.000 0.000 10.789 71.9
19 5 2005 21 7 73.3 88 69.5 29.865 3 7 45 0.010 0.000 0.000 10.789 71.7
19 5 2005 21 8 73.2 88 69.4 29.865 3 6 90 0.010 0.000 0.000 10.789 71.5
19 5 2005 21 9 73.2 88 69.4 29.865 1 2 45 0.000 0.000 0.000 10.789 71.5
19 5 2005 21 10 73.2 88 69.4 29.865 2 6 112 0.000 0.000 0.000 10.789 71.5
19 5 2005 21 11 73.2 88 69.4 29.865 3 5 90 0.020 0.000 0.000 10.789 71.5
19 5 2005 21 12 73.2 88 69.4 29.865 3 6 112 0.000 0.000 0.000 10.789 71.5
19 5 2005 21 13 73.2 88 69.4 29.865 1 2 135 0.000 0.000 0.000 10.789 71.5
19 5 2005 21 14 73.2 88 69.4 29.865 1 2 112 0.010 0.000 0.000 10.789 71.5
19 5 2005 21 15 73.2 89 69.8 29.865 1 2 68 0.000 0.000 0.000 10.789 71.3
19 5 2005 21 16 73.2 89 69.8 29.865 2 3 45 0.000 0.000 0.000 10.789 71.3
19 5 2005 21 17 73.2 89 69.8 29.865 3 5 45 0.010 0.000 0.000 10.789 71.3
19 5 2005 21 18 73.2 89 69.8 29.865 2 6 22 0.000 0.000 0.000 10.789 71.3
19 5 2005 21 19 73.2 89 69.8 29.865 3 6 68 0.010 0.000 0.000 10.789 71.3
19 5 2005 21 20 73.2 89 69.8 29.865 2 7 22 0.000 0.000 0.000 10.789 71.3
19 5 2005 21 21 73.2 89 69.8 29.865 5 9 22 0.010 0.000 0.000 10.789 71.3
19 5 2005 21 22 73.2 89 69.8 29.865 6 9 22 0.000 0.000 0.000 10.789 71.3
19 5 2005 21 23 73.2 89 69.8 29.865 5 9 0 0.000 0.000 0.000 10.789 71.3
