Some Questions for a modified WS2305 with WD 10.15
hi,
Iam using a WS 2305 and try to do some tests with WD 10.15 but there are some things that i dont understand.
I using a bigger rain sensor so my new calibration Factor in the station is now 0,131(default 0.518). I write this back to the station with a little program called WS2300 Statistik from Rainer Stein so the Station shows the correct Values when it rains. I dont know where WD reads the Data from the station when WD is online with the station. How can i get the correct Data into WD.
Next is the Datalogger Setup, there is no way to set the rain offset but think here display the station the original Values.
I think so because i have to set the rain offset in WSWIN to 0,262 to get the same data as the display from the station shows.
when i set the factor in WD to 0,131 WD newer show rain.
i hope o find help
Sorry for my bad english but i do my best.
Maybe
you will need to set a new modified rain tip, in the offsets setup screen, as
0.131/0.518
i.e
0.25
but, i have forgoten to use that in the data extract at start up rain
so i will have to add that, in the next version
hi Brian,
so that i understand you correct. i will try your example with my data next time it rain so we will see it works.
but at the moment there is no way to set a value to correct the data from the datalogger. and you will take it in your next version.
is that right?
when did i know in wich version it is implemented?
uploading a new beta now
i will let you know when its ready
try the latest beta version now
thanks a lot, i will download the new beta and we will see.
i send you a feed back ASAP.
