Sorry to write again about this, but I still have some troubles in the "customtextout.txt file
As I told you, if I switch on my computer on the morning, I open WD, and it reads the weather station’s inside recorded data (1 record each 15 mn)
Some troubles here… When I look my "customtextout.txt file, I have something like this
1014.0,9.6,8.9,9.6,7.9,9.6,88,0.0,ENE,0.0,26.6,5.4,5.4,466.8,NUIT,0.0, 0 %, 0,0.0,359,23:15,01/11/2004
this is the last value before disconnect the weather station (sometimes I switch off computer during the night)
1014.0,9.7,8.9,9.6,0.0,9.7,88,0.0,E,0.1,26.6,5.4,5.4,466.8,AUBE,0.0, 0 %, 0,0.0,360,08:00,02/11/2004
1014.0,9.8,8.9,9.6,0.0,9.8,89,0.0,E,0.0,26.6,5.4,5.4,466.8,AUBE,0.0, 0 %, 0,0.0,340,08:15,02/11/2004
1014.0,9.8,8.9,9.6,0.0,9.8,89,0.0,E,0.0,26.6,5.4,5.4,466.8,AUBE,0.0, 0 %, 0,0.0,340,08:30,02/11/2004
1014.0,9.8,8.9,9.6,0.0,9.8,89,0.0,E,0.0,26.6,5.4,5.4,466.8,AUBE,0.0, 0 %, 0,0.0,340,08:45,02/11/2004
1014.0,9.8,8.9,9.6,0.0,9.8,88,0.0,NNE,0.0,26.6,5.4,5.4,466.8,AUBE,0.0, 0 %, 0,0.0,360,09:00,02/11/2004
These are the first lines of the data after the disconnection…
The values are OK, but the hours and the date are false…
When it says "08:00,02/11/2004, it is “23:30,01/11/2004”, when it’s “08:15,02/11/2004” it’s “23:45,01/11/2004” and so on
it gives me the hour of the reconnection and increases it with 15 mn each line…
A few updates ago, it worked well…
Can you have a look at this ??
Regards…
