Solar woe's
I have been doing a but of research and I have found a possible solar sensor that will track the sun as it moves during the day.
www.springbokshop.com have some 1-Wire devices that they are developing mainly the LP-THS device. From what he is telling me, this new device sounds rather interesting and could make the 1-wire network rather interesting.
There is a new wiring system that is being designed which uses CAT5 cable and should be far easier to stop trouble. Also have a look at www.1wire.org where some documentation on 1wire standards and troubleshooting guides exist. I may be rehashing old ground, but I thought I might mention it for people.
Current Solar Graph
Current Solar Graph
Can anyone explain why my solar graph does this? The min solar is on -10?
and it has holes in it all the time? why i don’t know?
The ET is not being calculated at all, is there something I have set up wrong somewhere?
The other graph is constant and has no holes in it as far as I can see and it hasn’t actually dropped out as far as I can see at any point. Just this graph and the ET being bizare.
tucker , i think it will be a throw back to some old lost settting in the wdisplay.ini file
email me that file and I will see if i can see it (for the real time solar grpah -10 bug)
Version 10.20r
I have put Version 12.20r on now and the -10 problem looks as though its now gone, but can you answer me as to why there are gaps in the solar graph? I have a feeling that that is also effecting the readings for the ET and other related readings.
